With improvements to the Shaded rendering mode in Vectorworks Spotlight, you can create higher levels of realism in earlier stages of your design process.
This post will explore these improvements, specifically the three new tabs found in the Shaded Options dialog: General, Camera, and Quality. Through a combination of these tabs (plus the removal of an eight-light shadow limit), you can create realistic renders in real time directly within your model.
The General tab includes controls for the visibility of textures, colors, shadows, and edges, while the anti-aliasing option controls the pixelation of your visualization.
You’ll also find all of the lighting options in the General tab, such as environmental lighting, reflections, and object reflections. These options give you an efficient, direct way to access your lighting and background options.
With the Camera tab, you can choose to add various camera effects to your rendering, enhancing your Shaded views.
These effects work just like a traditional camera, but if you don’t have any previous photography experience, here’s a quick rundown:
These settings go hand-in-hand to help you create the precise views and representations of your designs you want.
Check out how you can manipulate the different settings together below:
Bloom can also be a helpful tool in your Shaded render toolkit, adding a glowing halo effect to lights you’ve placed in your set, stage, or live event design.
The third and final tab of your Shaded render dialog is Quality, which helps you control the detail and shadows of your rendering.
In addition to the greater control and customization the General, Camera, and Quality tabs offer, you can use different backgrounds in your renderings. As mentioned before, this rendering freedom that’s available directly in your production’s model can save you time and increase your productivity.
To discover the full potential of Vectorworks Spotlight's rendering capabilities and truly impress your clients with impactful presentations, click the button below:
