In any Building Information Modeling (BIM) workflow, models progress through different stages of development. Many begin as rough concepts but then evolve into detailed, data-rich representations used for design coordination, construction documentation, and facility management. But how do teams align on the specificity and precision appropriate to the phase?
That’s where Levels of Development (LOD) come in. Broadly, LOD defines the specificity of both the geometry and the data associated with each model element. It helps teams determine how much information is available at any given stage, making it easier to manage expectations and remain focused as a project progresses.
Vectorworks provides the tools to develop models progressively, track LOD status, and share the right information at the right time. Let’s explore the basics of LOD in practice and how Vectorworks makes managing it more efficient.
While Level of Development (LOD) and Level of Detail may sound similar, they serve different purposes:
For example, a door at LOD 200 might appear as a simple rectangular placeholder with rough dimensions and no specific properties. At LOD 300, the same door has precise dimensions, material assignments, and performance specifications—making it suitable for construction documentation. The difference isn’t just how the door looks—it’s about how much data is available for cost estimation, ordering, and installation coordination.
The 3D massing model represents basic information. Parameters like area, height, volume, location, and orientation are defined.
At this stage, objects may resemble the final design, but they don’t yet have the data needed for construction documents or precise cost estimation.
Generic elements are modeled with approximate size, shape, location, and quantities.
A door at LOD 300 is no longer just a placeholder — it has the correct size, swing, and material properties, making it ready for construction drawings but not manufacturing.
Model is defined by elements with specific assemblies, precise size, shape, location, and quantities.
This stage helps prevent costly errors—like a beam running through a ventilation duct—by ensuring that all systems are correctly coordinated before construction begins.
At this stage, a steel beam isn’t just a shape—it includes bolt-hole placements, weld details, and materials sourced from a specific manufacturer. LOD 400 is when a model stops being just a reference and starts becoming an instruction set for manufacturers and contractors.
LOD 500 isn’t just about having a complete model—it’s a tool for managing the building’s future, from HVAC servicing to fire alarm system upgrades.
Vectorworks provides BIM-integrated modeling tools that allow you to refine both geometry and data reliability as a project progresses through different LOD stages. Instead of rebuilding elements at each phase, you can develop your models incrementally, ensuring that objects meet the required level of accuracy and information for design coordination, construction documentation, and facility management.
A wall may start as a simple volume (LOD 200), later include material layers and framing details (LOD 300), and finally be ready for fabrication with fasteners and manufacturer data (LOD 400).
If a window lacks manufacturer specifications, it can be flagged for missing data before construction begins.
Instead of keeping maintenance schedules in a separate document, you can attach that data directly to building elements for future facility management at LOD 500.
LOD provides a structured approach to developing BIM models, ensuring that geometry and data remain accurate and reliable at every stage. With Vectorworks, you can refine objects progressively, track missing information effortlessly, and export structured data without disruptions. Parametric objects, data visualization, IFC export, smart data management, and classification tools work together to keep your workflow smooth, organized, and ready for collaboration. Whether you're focused on design coordination, construction documentation, or facility management, Vectorworks helps you maintain clarity and precision—so you can design with confidence.
Featured image courtesy of 5468796 Architecture.
