What is image projection or building projection mapping?
Image projection over buildings, also known as building projection mapping, video mapping, or spatial augmented reality, is a technique used to transform the surface of buildings or architectural structures into dynamic and immersive visual displays.
This concept involves projecting digital content, such as images, videos, animations, and interactive elements, onto buildings and other surfaces.
In this post, you’ll learn more about image projection and how you can do this easily in Vectorworks Architect, Landmark, Spotlight, Fundamentals, or Design Suite. By simply adding textures to the basic Renderworks light toolset, you can achieve beautiful projections regardless of the industry for which you’re designing.
You’ll also discover some common uses for this process in interior design, an area where image projection has lots of potential.
Creating a rendering using image projections involves a few essential steps to achieve a captivating result. For the remainder of this post, we’ll assume you have a 3D model created onto which you’d like to project an image.
Here's a breakdown of the process:
For a demonstration on using image projection in Vectorworks, check out our webinar, “Iterative Design for Interior Architecture.” Luis Ruiz, senior Architect product specialist at Vectorworks, will show you exactly how it’s done, and you’ll discover several other helpful techniques, such as working with embedded, custom, and imported geometry.
